AEG 4275 IM Dishwasher
2 Sep 2020
Hello all.
Have a problem with my AEG favourite 4275 IM Dishwasher.
I cant seem to find an answer online but at the moment I have both the DRY and END red LED lights flashing simultaneously.
The "drain" motor runs continuously and I have to mannually unplug it from the mains to switch it off.
I have taken both side pannels off and noticed water has been dripping onto the bottom pan. Underneath the main compartment is a white styrafoam board attatched to what I see is perhaps a safety cut off switch, so nothing else get damaged.
I drained the water, dried everything up and the machine works as pernormal. I have left all the panels off to see where possibly the water is coming from and the only thing that is wet or drips is a pipe that is attatched to the bottom end of the main water inlet ( the thinn plastic tank on the left hand side, looking at the machine face on). Everything else is dry.
If I leave this pipe in place, it continues to drip again and after two or three normal cycles the switch cuts in and both lights flash continuously.
I have had a look at the manual and it states to contact a technician when this happens.
I am happy to include pictures if this helps.
Has anyone else had the same problem with the AEG brand? or other models for that matter? It seems a waste to throw the machine out when it could be something minor to repair.
Any help on this matter would be greatfully appreciated.
Thanks.
