OK, a bit dramatic but I want to get it perfect 1st time.
The tiles are large format 600mm X 600mm floor tiles.
From my research a flat surface = success, so I decided to put down self levelling compound over the undertile cables.
The surface is level, although the compound has not created a totally flat surface.
I dry laid approx half of the tiles to see how the small variation affected how the tiles sat. What I noticed was some of the corners kicked up 1 - 3mm, not all the tiles but a few.
So the question (finally ) .....
Should I rely on losing these variations when I stick'um down (20mm U notch trowel (as per sticky))?
or plan b,
Go over the high spots with my orbital sander prior to laying and get them perfect pre-adhesive?
or plan b,
