I drained the central heating system to change a radiator and pump. Refilled ok and all radiators bled and also water pump.
I appear to have trapped air in the hot water cylinder (not cylinder to tap) but in the heater coil. I can see what looks like a bleed valve which is located on the end of a pipe running from the coil from the hot water cyclinder (pipe running vertically with a screw end). Is this a bleed valve - trouble is, I can't unscew it as it appears to be well and truely stuck. Broke several flat head screw drivers trying to open it (if it is the bleed valve).
Any suggestions - is there any other way of getting the air out of the hot water heater coil ?
P.S. all radiators okay but since turning pump up, need all bleeding again.
