Hi there I would really appreciate any help.
Ok I have moved into new built. Set temp control high to make heating come on so I could heating worked. Only bathroom. And kitchen dads work boiling hot too. Pressure on boiler (vital aqua varm hydraulic interface unit??) Is 1.3 cold. Hot water boiling hot etc. But all radiators from kitchen onwards are freezing. Now I no nothing but I bleed rads some had serious amounts of air. Then I pressurised boiler as dropped to under 1 and turned on. Still cold rads. Then I saw YouTube video saying to check rad valves where open anti clockwise. None were except ones already working. So opened them. Turned heating on again left for about hour still cold. I then checked the visible pipes running to from rads etc hot as far as second rad that works but everything after that is cold.....? I can see where pipes go from one rad through wall to next one in line so why after hot rad is pip cold coming out to next and all following rads after hot one are empty of water...well I think they are as took bleed valve completely out and nothing.
I'm waiting for the maintenance people who fitted to come well whenever they get round to me as I called Friday. The house is getting quite cold and wondered if anyone could suggest something Hubby could try to get it going?
