Alarm securit 700l
8 Jul 2015
Can anyone provide basic user instructions on the above alarm system
Someone in the Alarms, CCTV & Telephones section probably can. This section is for help with the new-look forum.
That was the first thing I did. But it does not explain anyway on the basic set up of areas.
Thank you.
There is an area already setup in the part set but it is not the area I want. Any ideas how to get this area off
You need the engineer programming book and the eng code, if you haven't got this you will have to default the panel and reprogram as required
