Alpha cb50 loose pressure
4 Jan 2010
Sheffield
2 weeks ago pressure dropping. After .4bar pump to 1 bar, Cant see leaks.
Pressure changed .5bar to1.5bar .5bar in minutes. off ,CH to on, then off,
1 bar high? (or 1-2-1)
Pressure vessel check OK, CH .8bar, water 2.5bar
Any Idea?
Please crap writing, a have aphasia.
But have pv at 2.5 bar, what do ?
Sorry, I gone wrong, I see (PRV) you mean.
There drops cold water in to tundish too.
Hi Kevplumb,
I tired my best, it not good.
CH expansion good, .8bar
DHW exapansion good, 2.5bar
Tundish is wet inside
The prv's both fed the tudnish
1 bar difference between cold-hot burner on.
OK?
I think the prv of the CH u/s
Boiler start at 1 bar, hot water get hot, pressure up, pvr blow at 2ish bar,
( too low) prv blow to 0, zero. Then filling loop squirt water in to 1bar again.
Is this OK?
There can you find these parts?
Please help is boiler.
Boiler all day, .8bar 1bar on the dial.
then 0 bar, squirt water to 1 bar, OK, boiler start , 1/2 hours later 2.8 bar , the CH PRV is squirts hot water to the tundish,
I me a hint.
Steve
I me a hint.
Steve
Hi, it's me after all these years. I can't believe that I posted in this way. Even I can't understand what I said. But I did fix the boiler, it was the PRV.
Cheers
