An unusual timer problem Worcester Greenstar Jr 24i
13 Oct 2013
Oxford
Hi
Newbie to the forum, but not DIY having completely renovated period properties over the last 35 years.
The problem is that on a Worcester Greenstar Jr 24i boiler the MT10 doesn't turn off...WAIT...I have read the threads.....even with a new timer fitted!
Even with a second brand new MT10 fitted, the unit switches on at the chosen times but never off when that selection comes.
So, what else needs to be looked at, please, to get the MT10 to work properly?
TIA
Vigman[/b]
I think you will need someone who knows how tom use a test meter to identify the problem!
Tony
Tony
Thanks. I have now also found out that the MT10 dip switches simply hit a lever one way or another for on and off and if this lever is stiff it will not be operated by the MT10!
There are only room stats in this unit, so I think a good idea might be to fit a room stat and bypass the MT10?
Vigman
Tony
Vigman
There is a batch of dodgy mt10's doing the rounds
The mt10's are pretty poor really. If your under warranty call Worcester out and they will most likely change it for the much better dt10 if you ask the engineer nicely. Ask me how I know ;)
