Hi all, im new here so hi to all.
I've been having problems with my suprima 50, not uncommon i see. Well first it started cutting out, then reset would fix same all story. Till reset did nothing anymore. Made a bit of a noise, then when release reset stopped noise and nothing lit. I got a gas man round and he said it needed a new pcb, £200 for board £100 for fitting.. so i decided not to take that route. I looked up and found compumerv on ebay, selling reconditioned boards that have been improved so they dont overheat and break again so easy. Got one today installed and dosent seem to have made a diff.
Curiously, not sure if this is normal or not. BUt even with the old board in. And again with the new one. The heating does come on now and then. But when you switch the heating to the on position on the control. To get the radiators on when its a bit cold. It wont light. But it seems to come on when its heating the water, and heat the radiators too.
I just noticed it was on so i tried, turning both the controls for water and heat from there current ON postion to OFF, This turned the boiler off. I then turned the heat back to ON, and it did not light. Some noise, but nothing happened. Then i turned the water to ON, and the boiler re lit and carried on..
If anyone can help me before im forced to call the gas man back out that would be really great.
thanks
thanks
