- Joined
- 27 Jan 2008
- Messages
- 23,696
- Reaction score
- 2,670
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was advised by my son to fit Nest, however I was sure it did not need such a complex control, only worried about two rooms, rest of house did not matter, so two thermostats one timed for night, the other for day, and theory the TRV would stop it getting too hot in the uncontrolled room, and the controlled room would be spot on. It worked for first 4 months, then it started to play up, I would visit to find it either roasting hot or far too cold, 3 month gap mother in hospital on coming out went to live with her. Tried fixing thermostat to wall, changing the jumper setting, moving it, the problem was the fault was intermittent and each time I thought it was working, week later it was playing up again.
This is when I realised about the quality, as I looked for a replacement thermostat I found the more expensive types actually had some simple S meter built in, it was not simple work or not work, you could see signal strength zero weak medium or strong. Then there are other features like learning how long it takes for a room to warm up, so it can reduce the hysterias, then it can be paired with the TRV so when the valve head calls for heat, the Nest also calls for heat.
All this has nothing to do with controlling from your phone, they are just better quality. As to time to heat up a room this has surprised me, at my home we have Myson radiators and within 15 minutes of heating coming on you feel the heat, but mothers house all simple water filled, house well insulated so radiators and boiler not that big, from 17°C to 20°C measured with web cam so away from radiator it takes some 3 hours, just nothing to move the air, near to radiator yes quite quick, but centre of room much slower, so if mother set to get up at 8 am heating needs to raise in temperature at 6 am. Cooling is just as bad, when it went wrong and room hit 22°C it took 5 hours before back to 20°C. Of course there are other factors, even in winter the morning sun can result in the room staying warm without any heating for hours.
So after a long battle with cheap RF linked programmable thermostats, I have gone for internet linked thermostatic control. Don't need the internet bit, what I do need is a quality device. Yes I will set to switch down the heat on days we normally go out, knowing I can switch it back up if coming home early, but that's not why I am getting it. I am going for internet control because the simple cheap RF linked programmable thermostats don't work. Having said that at home I have used a hard wired programmable thermostat for years, but that's with non condensating boiler and Myson radiators in an open plan house. Mothers house has traditional hall, stair case from the hall and landing. At home the stairs are in living room, simple arch between living room and dinning room, house was designed to be heated by a single central gas fire. True central heating.
So I need to admit now, there is a case for more expensive heating controls. I was really upset when dad had this central heating put in, there were hard wired thermostats on the old system, all wires for the thermostats were ripped out and RF type fitted instead. The big problem with the new set up was the thermostat was not programmable, it used a separate timer, so at night it did not reduce from 20°C to 16°C it simply switched off the heating. Hence why I fitted a programmable thermostat, but that one seems to have no repeat commands, so if it tells heating to switch off, it assumes it has switched off, and does not repeat the command.
