When I adjust to the timer to continous (or if it is timed to come on) you can hear the fan running but nothing else happens.
No clicks etc as if it is even trying to fire up.
I removed the PCB to check for anything obvious but nothing there.
I also had a new solenoid fitted a few months ago by an engineer but I do not know if it was the pilot light or the boiler one that was changed although I do know the physical location of the one that was changed.
Any ideas ?
Anything I could check or test, bearing in mind I am not a CH engineer, although I do feel comfortable checking wires and voltages with a multimeter as long as I am told where to ckeck.
Any ideas ?
