I see that washing machines come with a 13A fuse as standard when it may only draw around 4 amps. Common sense would say fit a 6A fuse. I intend to do this with my appliances, find out the amps drawn and put in a fuse to match.
Why are supplied fuses in appliance over rated? This surely must be less protection for the appliance and cables and flexes.
I noticed that flexes on some washing machines are not 2.5mm, so that cable is not protected fully. The flex could maybe draw too much current and heat up maybe causing a fire and the 13A fuse in the plug will not blow.
