Aqualisa Quartz gone mad!
20 Mar 2007
Buckinghamshire
Went to look at a Aqualisa Quartz (pumped)shower today.
When power is on (but control button off) It makes a noise like the pump is turning slowly and sounds like air is in the unit.
If you turn it on at the control it works fine and sounds normal.
But when you turn it back off it makes this odd noise again,and needs to be turned off at the fused spur to stop it.
I have disconnected each control wire end and refitted in case of bad connection
The is definitly no air in there.
Water is getting there ok
Anyone had this? Sounds like a problem with the pump units electrics to me.
Thanks in advance
had a few do funny things when not being used. changed the pcb's and been ok.
not saying its the same fault on yours.
have you had the top off while its happening ?
is it warm as if pump is trying to operate ?
Not had the top off,but sounds like pump turning slowly
Best description i can think of is it sounds a bit like a washing machine when it spins slowly just after fill up
Did not realize you could change the pcb,not had trouble with one before except under warranty
don't think you'll get them off aqualisa.
but i got them off the bloke i get most of my showers off and i think he can get the bits being an approved stockist.
but then i have had parts that i can't get and like aqualisa will tell you its a new unit needed.
when you take the top off look at the small pcb look at IC1 & IC2 that drives the pump they fail.
