I have purchased an Aqualisa Quartz thermo (unpumped) to fit downstairs. The instructions say I cant use a mains cold feed and a stored hot water cylinder supply. I thought about a pressure equalising valve but aqualisa say this wont work because it will reduce the hot supply as well, they say these valves are very restrictive. I am trying to avoid running a separate cold tank supply due to the number of floors and fitted carpets I would need to lift upstairs, any ideas please. I also thought about a pressure reduction valve on the mains cold only but again Aqualisa say it wont work due to reduced flow.
