From what I have been reading on the forum, I need to upgrade the wiring for my 3 x 150 w security lights which are fed from the garage lighting circuit. I plan to use 3 x Ashley J501 16 Amp Downlighter Junction Boxes inside garage fed by 1.5mm t&e, with 1.5mm arctic flex between each box and each external light. The lights are currently wired with normal 1.5mm t & e, which I read deteriorates with the sun and cold.
Does my plan sound ok
Can you get arctic/suitable outdoor flex in white or is it ok to paint it
Thanks again
Thanks again
