Hi guys,
I wonder if anyone could help please.
I'm having a problem with my Ariston Combi Boiler. All was working well until i noticed by water pressure was slightly low, so I manually upped the pressure to its correct value (Ive done this before with no probs). The manual states you should set the gauge between 1.0 and 1.5, but I accidently went over this to about 2.5. Whoops !!
Since then the hot water only lasts for about 1min as the flame just cuts out when runing the hot water. This is the same when turning the heating on, its lasts about 1 min. I have noticed though, that with the heating ON , when the flame cuts out the pump is still working.
Not sure if the water pressure would affect the flame cutting out, but could some please help or let me know if they've had a similar problem
