Hi all & Happy New Year,
Looking for advice about an Ariston EuroCombi A27 which is giving alternating hot&cold water and central heating.
The burners fire from a cold-start, but once it has been on for a minute or so, everything (pump+fan+burners) stops dead. A few seconds later it starts whirring again, the burners fire after around 20 seconds, it all stops dead again around 35 seconds and the cycle repeats.
The effect is that DHW goes between freezing and very hot water - the hot taps and shower keep cycling between hot & cold.
CH radiators get warm, but if you touch the CH feed pipe coming out of the boiler you can feel it going hot & cold with each cycle - same as DHW.
Two plumbers have tried to fix it, starting with replacing the Air Pressure Switch (there was another fault a month ago - it wasn't starting until given a thump), cleaning the venturi and the fan, cleaning a temperature sensor and replacing the bottom-right control PCB (pump relays etc.). They just put X800 through the CH system and that doesn't seem to have helped.
I'd be v.grateful for any ideas on what could cause the boiler cycling.
Odd thing is I didn't notice it doing the cycling until the other fault (with the APS) was fixed - showers were cold until you gave it a thump... Ah, Ariston
