Hi guys,
I've moved into a house that has had armoured cable laid from the outside wall of the house down to the garage. I need to get it into the house so I can make the necessary connections in order to get power down to the garage. I have 3 questions about this though:
1. I have the gland/cover for the cable, but am unsure of whether it needs to be terminated into a plastic external junction box on the outside wall, or a round type galvanised 'socket' that I've also seen whilst out and about. Or should I just continue the AC all the way through the wall cavity and up to the CU without switching to internal style grey cabling?
2. The internal copper cores of the AC are i think 6mm. What size cable do I need to therefore run from the point at which it enters the internal wall of the house to the CU..... 6mm also preseumably? can you get 6mm T+E?
3. At the garage end i'll be adding a small garage style CU which I'm assuming will have a RCB on board that end. Should I also fit a mini circuit breaker RCBO type thing on the house CU feed also? 32 amp?
Many thanks,
Phil
Many thanks,
Phil
