back boiler problem
1 Feb 2010
Devon
hi was just wondering if any one could help me out with a minor problem, i have a baxi back boiler system and one of the rads upstairs is always half cold,
i have bleed the system several times and it still does not solve the problem ,
the expansion tank in the loft is full and the ball cock working fine so am lost as to what to do next, any ideas would be gratefully recived
ps. forgot to say when you bleed the rad in question no water comes out its like the rad is only half full, you some times get a small hiss of air if i have't bleed it for a while but thats it.
some times a very small amount , but just sat there for 10 min with the valve open and nothing came out
Try bleeding when the pump or heating is off, when the heating is on the air could be sucked into the system instaed of vented
ok ill switch heating off and give it a try,
is the pump the one beneath the hot water tank or behind the cover on the fire ?
if it is the one behind the cover it is on leval 2 the one in the airing cuboard is not numbered there is just a large flat head screw to turn
also forgot to say when the heating is off the rad that stays half cold is luke warm not sure if this makes a difference ,
thanyou for your help by the way as you may of gatthered my plumbing knowledge is pretty crap
thanks guys ! im an idiot just switched the heating off bleed it again and problem solved , i only ever think about it when the heating comes on so never bleed it when the heating is off , thats todays lesson learnt ! thanks again to all of you
