- Joined
- 27 Dec 2017
- Messages
- 53
- Reaction score
- 1
- Country
I think I posted in the wrong thread before. Anyway....
Hi all,
I have posted before and have since been disputing with the person who laid this patio. Basically, I had the patio laid and stupidly I knew nothing about the 150 mm rule. He has not laid it to this depth. Anyway, if you look at the picture you will see the bottom row of bricks are wet. This happens nowhere else on the patio where in some places it is at the same height.
I am saying it is the patio causing the problem. He is saying it is the weather. He says if the patio was causing the problem it would be the same everywhere. He is refusing to put this right. He says the patio slopes away from here (which it does) and water does not accumulate.
You will also notice I have pulled up some slabs and filled with stones to let the area breath, it has not done anything.
Should I be concerned? The ground is a clay base. It is all a bit messy.
Hi all,
