Hi All,
I have an annoying issue with my combi boiler (fer falcon) in that my mixer shower (manual type from the taps) seems to cycle between being nicely hot and just luke warm.
The flow rate from the cold tap is around 12 l/m and from the hot it's around 7 l/m - although i tested this at night and it seems to be less than this in the morning (maybe because everyone down the street is taking a shower??).
Anyway, what could be causing this annoying fluctation in the temperature? My only thought is that the flow rate could be too low and the boiler is therefore turning itself down to prevent the water getting too hot and then turning itself back on again?
If this is likely to be it, what can I do about it? I've read somewhere in the boiler's manual about there being a flow/pressure restrictor on the cold inlet to the boiler - would removing this help and, if so, where can I find it?? If not, could I turn the DHW temp on the front of the boiler up to prevent the boiler thinkng the water is getting too hot?
Sorry for the long post - just can't work out what's happening.
Thanks for any help you can give.
Ben
Ben
