Hi all, me again,
Have sorted out my heating issues, was an issue with the stainless hoses that were fitted many moons ago.
I will be draining and flushing the system next weekend of the fernox f5, and installing fernox inhibitor for their filter.
When I do this for the last time hopefully, I will go around and balance the radiators again, as some of them are hot in places and cool in others, however I am now pretty certain this is a balancing issue.
Although the main culprit which has been all along is still the coolest and is the 4th rad on 15mm pipe.
The boiler I have is a ferroli domicondense 26 he, there seems to be vastly conflicting information all over the internet to what I balance the rads to (not specific to the ferroli but condensing boilers in general). I can't seem to get a 20 degree difference between the flow and return on any individual rad, but I understand condensing boilers are best when the return is 55 degrees or less, do I set the temperature of the flow to be 65 degrees as it leaves the boiler and set the rads at the 10-12 degree difference and hit the magical 55 degree return for the condenser?
Lastly when I moved in the pump was always set to 3 now I have the heating working and have removed the majority of the restrictions I have turned the pump down to 2, this was also to aid the temp difference, however again I have read conflicting information, but most seem to say the pump.on a combination should always be on speed setting 3?
Hopefully you guys will be able to provide me with some definitive answers.
Thanks in advance
Thanks in advance
