DP wrote
So if the OP,s two radiators which are not heating up properly have a high resistance then this fixed balancing valve will have to be closed fairly tight in order to acheive a flow through them.
I only say this because the lockshield valve on my radiator closest to the boiler is turned on by about a 1/4 turn in order for it not to short circuit the flow to the rest of the system . Its also before any zone valves and when I operate it alone the by pass kicks in returning high temperature water back to the boiler.
If I tried to balance the system as if the hot water circuit is a radiator in order to acheive flow to the CH circuit then on HW only a dribble would be passing through the coil because of the fixed balancing valve and the by pass will be operating just as it does when I have my single radiator turned on.
I find my cylinder of water re-heats in about 25 minutes with no boiler cycling which is not a very long time and a few of rads closest to the boiler warm up when HW and CH on simontaneously. The HW valve then closes and the CH heats up as normal.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I would suggest installing a valve on the cylinder return pipe as it is causing the imbalance.
