bamboo flooring
13 Apr 2005
I would like to use bamboo flooring in my bathroom it is 17mm thick solid wood laminated ,any reason why I should not do this.???
Composed Bamboo (when layered but using same material).
Is fine to use in bathrooms, but still remember: excessive moist will have some impact (but not as much on Bamboo than on solid Oak for instance, reason why we always recommend wood-engineered flooring in bathrooms)
Thanks for your advice Woodyoulike there are only two of us no kids, so should be able to keep it reasonably dry.
I laid bamboo in my bathromm around two years ago and it hasn't budged so much as a millimeter read somewhere of a school gym in USA that had been flooded for over a month and was fine when it dried out
Hello,
I'm about to renovate my kitchen, we have chosen Bamboo flooring,do we need to use any type of backing? The type of Bamboo floor we choose is a compressed fiber type with a ceramic top.[/img]
I fixed mine to 4mm ply screwed to the floorboards with plenty of screws (every 6 inches due to the small screws and thin board) so as not to increase the height too much and glued it down with Parquet adhesive, not sure which one but think it was lecol.
