Im just about to fit a new bathroom all by myself (scary stuff as Im very new to all this).
I have stripped off the old tiles from the walls, and have a mixture of a rough surface where the old tiles were, and bumpy artex above a certain level (as the walls weren't completely tiled).
I want to fix the bath in the corner, and use the hose from the tap as a shower.
I've scoured the internet as to what I should put on the walls to make them water proof, and I've come across gypsum, green board, cement fibre boards, PVA seal etc etc.
I guess the best approach would be to have the walls plastered, so that they are even, but what of the previously mentioned water-proofing should I use ?! None of them seem to be easily purchased in any bog standard hardware stores here in the UK (Homebase, focus etc)
Would I use the same on the floors as well, as I intend to put down floor tiles, once I have put a covering of some sort over the wooden floor ?
Can I just tile over the walls as they are without re-plastering (baring in mind in a beginner) ?
I would be incredibly grateful if some one could give me some guidance.
P.S. I want to do it as cheaply as possible
