Bath hot water tap faulty?
11 Jul 2010
The hot water coming out of our bath tap is lacking pressure to the point when it hardly comes out at all. Hot water from the rest of the taps in the house work fine.
I check the hot water valve under the bath tap and it opened/closed with no issues.
How can I resolve this please? Can I repair the existing bath tap or with new washers maybe or do I need to replace the unit?
Cheers!
Tom
washers probably stuck shipmate.
isolate supply, dismantle tap, replace washer.
gloat to your missus that you're a diy god
Thanks Alz0r for the quick response.
However, I just went to isolate the supply and hot water still trikles out of the tap and when I turn the screw on the hot water isolating valve water comes out of it a little bit so I guess that's had it as well.
The hot water tank is full of water and there are no more valves to turn off so do I have to drain the tank and then replace the flexible hose?
Thanks again,
Tom
Arew other hot taps ok.
Could have a piece of s**** gone down the pipe if problems on all hot supplies
The bathroom sink and kitchen sink hot taps all work alright.
I swapped the valves over on the bathroom taps and it makes no difference. The hot water still comes out like a dribble.
I think it must be the valve on the flexible hose so I will look at that next.
Cheers,
Tom
The valve on the flexible hose dribbles very slightly so I guess it's losing pressure there. Will replace and see what happens!
Cheers,
Tom
After replacing the flexi hose/valve the water pressure has been restored. Will keep an eye on it, however, at least we can run a bath now.
Thanks for your help chaps!
Cheers,
Tom
