hi all, my mother has a wet room as she is disabled, however she now wants To go back to a bathroom suite my query is can I run the bath waste pipe into the existing drain for wet room
Cheers in advance
No. Particularly if said drain will be hidden under the bath. What if it blocks up? First you'll know is when theres a massie puddle of water emerging from under the bath. Dig out the wet room drain and connect onto the 40mm pipe.
