Im in the process of turning my old Bathroom into an En-suite.The House was rewired just after the new colour code came out and has only a existing light in there at the moment
I want to install Extractor fan/light in the shower cubical ,Heated Mirror with built-in shaver socket and 2 down lights
should i
1)Run everything of the existing upstairs lighting Circuit
2)Run a separate feed of the CU for Mirror only
3)Run a seperate feed of the CU for Mirror And Fan
4)Run a seperate feed of the CU for everything and remove the existing wiring for the bathroom light
Its every easy to run a new feed if necessary as the CU is right below the old bathroom
thanks
should i
thanks
