hi all,
I'm a bit confused (as usual ). Under regs:
1. Do low voltage (i.e. 12v) downlights in a bathroom need RCD protection?
2. Does a 240v extractor fan in a bathroom require RCD protection?
3. does a SELV extrator fan in a bathroom require RCD protection?
Also, I would like dimming lights, but the extractor fan to be controlled via the lights being turned on. The dimmer will be located outside the bathroom. Is this at all possible? Would the fan turn on ok if the dimmer was only turned half way for example?
Thanks,
Alex
Thanks,
Alex
