Baxi 105E Instant
4 Oct 2004
:rolleyes:
baxi 105e instant cold tap problem
System is fine but when i turn off the cold water tap the boiler fires up. any ideas
if i turn the tap off slowly it does not happen?
A bit of air trapped in the pipe will make a combi do that - the water bounces a bit, enough to trip the pressure switch.
Thanks Chris, how do i get the air out?
is there a bleed in the boiler?
hot water out or cold water in?
Thanks David. :LOL:
Has it done it since it was fitted, if so you probably have a dead leg on the hot water pipework which needs removing.
thanks PEDANTICVINDICTIVEMAN it has done it since instalation.
at first i thought it was normal but it is starting to get on my nerves.
what is a dead leg?
thanks david :eek:
