Hi all, have an intermittent problem with my Baxi 105e. When heating gets up to temp and the boiler stops burning it won't come back on. No flashing lights, reset boiler and turned off at the mains and it came back on.
no flashing lights...no fault code...unusual too...could be pcb.thermistor.thermostat...but you do usually see flashing lights when internal components go tats up
Thanks @durhamplumber. Not 100% sure but when I closed the front hatch on the Baxi all the red temperature lights went out, I opened the hatch straight away and they were on, could be imagining this. .
House is empty as tenant moved out but going up again today see if it does it again.
