Baxi 105e
7 Jul 2006
Hi all and hope you all had a nice Xmas and looking for a good new year..now the problem with the baxi 105e it starts ok in both DHW & CH but after seconds stops and the no flame LED start to flash, I noticed one thing that when the burner is on the spark does not stop, reset and the same thing happen, checked the lead to the sensor it looks alright, is this down to the PCB?
Sounds like a fair bet if all else is working as it should... The PCB is not registering that the boiler has lit and so goes to lockout..
Hi all,
Your flame rectification is not working, by the information you are giving us. Physical check isn't sufficient, the need for a multimeter is in order ;) Suggest you find a local RGI...
