Baxi 35/60 Gas Boiler
30 Dec 2009
I have a House with a Baxi 35/60 Boiler. Running fine for 5 Years but recently the boiler has begun to drip water from a 1/2 " pipe coming from the bottom of the boiler. The Boiler is wall mounted approximately 3 ft from the floor. The pipe is now leaking 20 Liters / Day and I have a large vat under it to collect the flow. The pipe come from what appears to be a valve in the bottom of the unit . It has a red knurled plastic knob.
I think myself that this is a pressure release valve but am not sure.
Pressure indicated on the Pressure gauge is 2.5Bar when the system is operating.
Could I reduce the pressure in the system bu slowing the pump or by reducing the head in the top up tank in the Attic?
Any ideas welcome.
Ted Power
don't know of a baxi 35/60, sounds to me as though you have a sealed system and the filling loop is passing/turned on - with 2.5 bar you are unlikely to have a top up tank in the attic.
Thanks for the response Mick.
I will look for the Fill Valve and see if it is cracked open.
Regards,
Ted
