Hello everyone, I have found this forum and hope someone may be able to help me...
I have a baxi combi boiler 80e , it has always been fine it is 7 years old, i turned the heating off in the spring and have been on DHW ever since, last week put it onto water/heating mode and absoutely nothing.
The hot water is still working fine on both settings ie on tap symbol and tap/heating symbol, there is just no sign of heating, no failure lights are flashing, pressure is fine, the thermostat in the room has been checked by an electrician and is calling for heat with correct voltages, theres just nothing happening on the boiler, the main green on switch is lit, i wondered if anyone had any suggestions before i spend out on a pcb board/engineer as i have read so many posts that say changing the board didnt help, many thanks for your time, as my user name suggests we are getting very cold! thanks mandy.
