After having DHW problems recently, I changed the DHW diaphragm and the DHW sensor, which seemed to solve the issue and everything appeared to be running tickedyboo. However in the last day or so, my partner complained the hot water only worked when the heating was on. After checking, the boiler fires up on request of hot water, but it's only coming out luke warm. Am I right in thinking my DHW heat exchanger is clogged up, and if so is there any particular way of cleaning it. However if there are any other suggestions as to what it might be , i'm all ears.
Thanks for your time.
