Wow. You guys are keeping me on my toes. I thought I had it cracked, but nothing is happening as I expected. The boiler is still running (11:20) and hasn't tripped yet. I have an open mind about the pump. I thought that, as it was clearly pumping the water, all was well. I now accept that maybe it isn't.
I don't have any instuments to check water temperature. Using the touch method, however, what I can say is that I can hardly bear to touch the flow pipe, whereas I can keep a finger on the return for about a second or so. There is clearly a significant difference in temperatures, but it seems to me to be about what I would have expected (bearing in mind that I know nothing about boilers but I am a retired engineer with a lot of general practical experience).
As regards the pump, it may be my imagination, but it could be humming a bit louder that it used to. I wouldn't put a lot of weight on this though as I am not in the habit of sticking my head in the landing cupboard to listen to the pump. Looking at the external lever, I noted that it was set on three. however, when I turned off the power and stopped the pump to remove the cover, I discovered that the connection to the speed rheostat had sheared off. I managed to turn it using a small screwdriver and I cranked it backwards and forwards a few times to maybe clean up the contact with the rheostat. On switching the power back on, the boiler power light came on, but it didn't fire up. The pump sounded just the same and I left it on speed setting three. After a while, the boiler fired up and has just now shut down, having satisfied the room stat. I have just turned up the room stat and the boiler has fired up and the pump started. In other words, the boiler is behaving itself and the system is working normally. I would rather there be a specific fault which could be rectified. It's a bit worrying as I am going on a cruise to the Canaries on Monday and, while taking the sun in Lanzarote, I don't want to be thinking about my house freezing up back home. Any further thoughts?
