gas4you said:I take it you mean you have a Baxi system boiler and the drip is coming from the pressure relase valve pipe outside rather than an overflow from the loft?
Bamber gaspipe said:gas4you said:I take it you mean you have a Baxi system boiler and the drip is coming from the pressure relase valve pipe outside rather than an overflow from the loft?
If he has a system boiler, he won`t have a blow off, it`s not pressurised.
kevplumb said:why does a system boiler have a gauge then
very unlike you to make this sort of mistake
kevplumb said:very unlike you to make this sort of mistake
tought thee well fella
Bamber gaspipe said:kevplumb said:why does a system boiler have a gauge then
Do they? always? Explain system boiler.
kevplumb said:system boiler has the ex vessel pump etc in the case
leave it alone bonny lad
