I have a baxi duo-tec that's been installed for about 2 years, since coming back on this season, the system has been losing pressure at a dramatic rate, requiring topping up daily to start with, now twice a day.
I've spent a day checking the system for leaks as best I can, didn't find anything, but I don't think it's that. When the system was running at full temp, system pressure went up to 3 bar, so I concluded that the expansion vessel was either not pressurised or failed.
So I pumped up the expansion vessel to just over 1 bar. The next time I fired it up the system pressure stayed at about 2 bar when running, so I figured it was fixed, but then the system rapidly lost pressure over the next day, needing topping up twice to stay running. I presume that the extra pressure loss was due to the expansion vessel deflating again. So on the off chance the valve was a bit dicky I WD40'd it and pushed the pin up and down a bit, then re-pressurised, but it lost pressure again just as quickly. There also seemed to be a bit of water coming out of the valve when I let it down.
It seems to me that a failed expansion vessel is the only reasonable explanation, but I'm no expert, so before I go to the trouble of replacing it, I thought I ask if there were any other plausible explanations, or things I could try.
I was going to isolate the boiler from the system and do a pressure drop test on just the pipework, but it hardly seems worth it when the 3bar running pressure seems to point strongly to the EXV. I suppose the other possibility is that the PRV is leaking, but how do I go about checking that?
Any more knowledgeable advice would be gratefully recieved.
Also, replacing the EXV looks fairly straightforward (I put the system in myself except for gas and boiler commissioning, so I have some idea what I'm doing!) but is it legal/sensible to attempt to replace it myself?
