Had problems with my baxi solo 2 for about 5 years
It kettles after about a minute of being on.
Since it started doing it I've had 2 plumbers in and we've had the pump replaced twice and new motorized valves fitted near the hot water cylinder.
I've had the heat exchanger out numerous times and flushed it through with a garden hose.
Taken a radiator off and flushed the system through both pipes with a garden hose.
The last plumber that came round said it could be the heat exchnager has just too much corrosion and limescale in to shift, does this sound right ?
Anyone suggest a similar replacement boiler that is more reliable ?
thanks
thanks
