Hi
I have a Baxi Solo 3 this morning I put the heating on and nothing happened. Checked the boiler and there was nothing on at all, turned all the power off to the boiler and control panel and then turned it back on.
Nothing happened when I turned the Heating on but it came on when I put the water on it came on for 5 minutes then went off.
Since then NOTHING comes on and the lights on the boiler are all off.
There are the following lights :
Overheat
Boiler ON
Fan ON
Pilot ON
Burner ON
Ive checked the PCB board and changed the fuse the only thing that does happen when I switch on the power is that an LED on the board flashes when I turn it on and then flashed when I turn it off. Other than that nothing happens no clicks no fan nothing.
any ideas when I could start.
Overheat
Boiler ON
Fan ON
Pilot ON
Burner ON
