I have Baxi Solo 3 boiler and megaflow hot water cylinder (3years old), I have just had to change the combustion fan, it looks like the die cast bracket that supports the motor has got hot causing it to sag and the bottom cooling fan has touched the casing causing the motor to overheat and burn out, the top cooling fan had also fallen off.
Having replaced this the boiler is now turning its self on and off every 1 to 2 minutes. This morning I set it to come on at 5.30, by 7.00 the rads were not hot by 9.30 they were.
I'am just wondering whether this caused the combustion fan to malfunction in the first place?
I will check the obvious i.e connections and dry joints on the PCB.
Also I've notice the system pressure seems to vary from low to high sweeping across the green operating band.
Any help greatly appreciated.
Julian
Julian
