baxi solo 60pf fault
27 Dec 2008
Glasgow
my baxi solo boiler has developed a fault when the system is cold the boiler will light and run for a few mins then the boiler light goes out and the pilot igniter keeps sparking but will not light, :mad: everything else looks ok.
any help would be great as it was -3 last night.
cheers big al
This sounds likely to be a safety device associated with the combustion process but it could also be a PCB fault.
I expect that you are going to have to call a competent CORGI.
DP who posts on here probably covers your area. You could contact him through his profile or look up Ranoch Services locally.
Tony
