Beach Buggy Restoration,
Discussion in 'General Cars' started by BigRobCanUFixIt, 26 Jan 2012.
  1. BigRobCanUFixIt
    29 Oct 2009
    424
    Thanks Received:
    27
    Country:
    I thought I would share my car restoration project which has been ongoing for some years but will hopefully be back on the road this summer.
    Its a 1972 GP Buggy built on a shorten VW beetle chassis
    This is it befor restoration started.
    [​IMG]
    It looks ok but there is a lot of rust under there and a lot of bodged fices over the years, and the engine only done another 900 miles before it went pop.
    Stripping begins
    [​IMG]
    [​IMG]
    Removed and refurbed front suspension and welded in adjustes for ride heights
    [​IMG]
    Tin worm beware
    [​IMG]
    chop chop weld
    [​IMG]
    painted shiney shiney
    [​IMG]
    next side, the pans were made by me in my dads sheet metal workshop
    [​IMG]
    call in reinforcements
    [​IMG]
    wiring starting to appear
    [​IMG]
    low carb diet!!!
    [​IMG]
    bright light
    [​IMG]
    who needs ramps
    [​IMG]
    welded, sikka flexed rust proofed and undesealed
    [​IMG]
    top done
    [​IMG]
    The Stig!!!
    [​IMG]
    [​IMG]
    [​IMG]
    time for a brake
    [​IMG]
    Put your foot down
    [​IMG]
    shiney dram brakes
    [​IMG]
    More wiring
    [​IMG]
    Hopefull will have some pics on the road very soon :)
    Rob
  2. HERTSDRAINAGE2010
    9 Apr 2010
    6,463
    Thanks Received:
    905
    Hertfordshire
    Country:
    Looking good Rob.
    Andy
  3. Burnerman
    7 Feb 2008
    16,411
    Thanks Received:
    3,187
    Northumberland
    Country:
    A cracking bit of work Rob :cool:
    I bet you're pretty hot with the MIG after that one.....some awkward corners there.
    John :)
  4. Mursal
    23 Sep 2010
    2,162
    Thanks Received:
    479
    Country:
    Ireland
    Thanks for that, takes me back to when I first started fixing
  5. Graemevw
    18 Dec 2011
    122
    Thanks Received:
    2
    Derbyshire
    Country:
    Why didnt you use a new pair of floor pan halves?
    Depending on how low you want to go, caster shims, long travel ball joints and bushes to drop the steering arms underneath help alot, not needed if you dont go super low though. Im guessing you probably know this anyway.
    From my time mesing with old VW's, making them alot quicker, i found solid rear swing arm bushes and rear frame horn braces a good mod, really tightened up the back end and eliminated wheel hop on hard launches.
    Do you know what happened to the engine? Are you re-building it or replacing?
  6. BigRobCanUFixIt
    29 Oct 2009
    424
    Thanks Received:
    27
    Country:
    Hello Graeme,
    The pics of the front suspension was my first effort where i welded the adjusters in upsidedown lol.
    I want a standard is ride height but as the car is lighter than the beetle and even though the torsion suspension has sagged slightly it wasnt low enough,
    I have fabricated my onw pans as the bought ones are like tin foil to thin compared to the stock ones. And also I am going to checker plate inside so wanted something flat. I cross braced the underside to try to stiffen it all up a bit.
    The old engine was knackered about 15mm of endfloat type 3 1600, So I bought a 1600 lump type 1 with none and rebuilt it new pistons barels rods, heads etc to 1641 and had twin carbs which were a bit shagged so now running it on a single dellorto I just need to get the wirng done, tyres and the MOT it.
    The seat frames I got from hallford sale bin at 1.50 each modified them as they were for a fiat punto. hehe
    roll on the warmer weather.
Share This Page
