Hi, I'm fitting some new wardrobes in the bedroom. As I do not want them to stand away from the wall (by the skirting depth) I wondered if there is a replacement 'thin' skirting? Ideally I would remove the old skirting, fit new, then fit new carpet (without grippers in the wardobe area). Is this sensible or should I just remove the skirting behind the wardrobe area after carpet has been fitted (requires careful cutting of the skirting in situ)?
Ian
Ian
