My old eco-tech boiler has packed up and apparently eco-tech have gone bust.
The old boiler used to work on a continuous flow that fed four manifolds and the only control over the boiler was the return temperature. (each room has a thermostat that Controls the manifold) Not only did it have a modulating burner but it also had modulating pump. The computer on the front of the boiler use to display the percentage the pump was pumping even when the boiler wasn't running so that there was water flowing through the system so it could monitor the flow and return temperatures.
At night the thermostats in each room retarded the temperature of the room to save energy and early morning bring the room back up to the correct temperature automatically, if you looked at the controls on the boiler in the evening the pump would be pumping 5 to 6% and the burner maybe at 10 to 15% excellent old boiler.
We found over the years that this boiler was highly efficient and I'm looking for another to replace it.
Four bedrooms two bathrooms one kitchen two living areas all with underfloor heating.
Pressurised domestic hot water.
If anyone can think of boiler and point me in the correct direction I would be really happy
