If I want to make a floating bookshelf around 7-8 feet long (i.e., has to carry a real heavy load), what would be the best method between these two ...
1) 2x4 skeleton and put plywood or plank box over:
2) Buy iron rod brackets:
https://shelfology.com/shelf-hardware/aksel-md-floating-shelf-brackets/
I'm looking to make a shelf around 7 to 8 feet long and about 12" deep.
I may have to give up the idea of a floating shelf and just use L brackets, but I wanted to get opinions first. Do you think either of these methods would work? Which would be stronger? Is there a risk of the 2x4 skeleton drooping over time?
I should add that I am fixing to a plasterboard wall with wood studs spaced at 60cm/~24" apart.
