best plug to go into a breeze block for a door frame ?
26 Mar 2008
Bristol
Just tried 2 different ones , both have spun and made a mess so no good.
What say the massive as the best plug to put into a block to secure a firedoor surround
well i usually have no real problems with the brown plugs,but if there really that weak perhaps try using a 6mm drill bit and bang in a brown plug,also once done you could also use some expanding foam as well,BUT MAKE SURE EVERYTHING IS LEVEL PLUMB AND NOT IN WIND before doing this.
the big black plug.
you can find them in your sink or bath
Your misses might not be pleased but that is what showers are for.
