As an aside, when I built my bathroom (as a DIYer) . I went for a double ended bath- I regret it at my leisure. After using it, I use my pull out showerhead to clean it and rather than running to one end, the "fluff" approaches the drain and stops.
30 year manufacturers guarantee covering all defects1700 x 700 x 550mm (length x width x height)Made in the UK from 4mm thick sanitary grade cast acrylicInternal depth of 420mm at the deepest pointFeatures an intensive fibre glass polyester reinforcementWater capacity approx 185 litres estimated...
