Hi guys.
As per the title really.
I used to use an angle grinder with a masonry blade but it was slow and dusty.
I then purchased a cut off saw with a 305mm blade. Goes through 100mm blocks in one pass so i was cutting in about a 3rd of the time as i was with the grinder, however i find it difficult to make a square cut without marking 3 sides of the block first, and the dust it creates is outrageous.
I then purchased a hydraulic block splitter, no dust, but the cut was that bad id end up having to go over the ends with the cut off saw anyway so 8 ended up selling it.
Im now considering the dewalt cut off saw as it has the water system to suppress the dust, but the cut depth is only 83mm so ill have to make 2 passes on a 100mm block and back to the cutting square issue, plus it is £500.
Does a system exist that will allow me to cut 100mm block in 1 pass, squarely, with minimal dust, sub £500?
Or what would be the next best thing?
