Had to remove bath panel to get to drain to clear some hair out.I'm going to be adding a mastic sealant (for bathroom which is mould resistant) around the panel once its fixed in place.Any advice?How do I get the best finish?
I'm going to have a practise on something else first.How about cutting the sealant tube end?Whres best to cut it,at an angle or try to cut it so that it comes out at the thickness you want it?Finishing can you use soapy water on your finger to fsmooth and finish it?
