Bevelled tiles / Beveled tiles
17 Apr 2007
Leeds
My wife has purchased bevelled tiles (Biselado / subway) for use as a splash-back in our kitchen. The dimensions are 150mm x 75mm, we intend to tile them brick style;. See link for an idea of the style and look: http://www.wallsandfloors.uk.com/ranges.php?rid=12&t=Tile
We have a number of external corners (chimney breasts, window sills etc.) that would normally be solved by conventional plastic corner edges, however the bevelled edge of the tile are causing problems, as they do not fit fully into the edging strips .
Can anyone provide an attractive solution to our problem?
Thanks.
Paul
I will have the same problem soon (daughter@s bathroom awaiting exchange of contracts) but had not thought about it until now!
How about planning it so all the corners are cut tiles...
Use an edging strip for thinner tiles where this is not possible . .
Hi IJWS15,
planning it so all the corners are cut tiles would not work as the sides of the tile are also bevelled. This would leave a strange side profile.
I see what you mean
She is getting a flat with Johnson's "polar white" and wants some more adding so she can use a shower over the bath.
